Creating a domain for dispersion simulations
Old   February 21, 2016, 12:24
Default Creating a domain for dispersion simulations
prij is on a distinguished road
I am a new user to Ansys and needed some help on how to create an air domain outside a pipe whose one end is dispersing supercritical CO2.
This is what I did initially. I created a pipe first and then created a frozen around that in such a way that one face of the pipe matches with one of the faces of the frozen surface. I then applied Boolean operation to subtract one solid from the other retaining both the solids. After meshing and importing that in Ansys Fluent, it shows to me that the dispersing end of the pipe is an interface and cannot assign 'mass flow rate' BC to that end. Then I changed it to Fluid in my design mode. But still doesn't help. It now says unassigned interface zones found, flow not initialized.
I have attached a sample figure.
prij is offline   Reply With Quote
decomposition of multi domain cases for large simulations romant OpenFOAM Pre-Processing 6 May 10, 2023 22:27
Domain Imbalance HMR CFX 5 October 10, 2016 06:57
Rotational porous domain Pifpoffele CFX 1 July 6, 2015 12:46
Problem with creating a domain in hexpress glasgow_andrew Fidelity CFD 2 March 11, 2014 13:04
Help with creating a plane in the domain Tony CFX 2 September 14, 2004 19:12
