Help with "AMG divergence: Temperature" for choke flow simulation
Old   February 17, 2016, 02:26
Default Help with "AMG divergence: Temperature" for choke flow simulation
Jet
Leviro91 is on a distinguished road
I am currently doing my final year project for undergrad involving cfd simulation for the erosion of a choke. Hence, I apologize beforehand if my question is too basic.
The material is a species mixture comprising of mainly methane together with nitrogen, CO2 etc. I run it with a volume weighted average density method in order to run without the energy equation. It works fine. However, after changing the density method to incompressible ideal gas, the solver gives me a temperature divergence error after about 50 iterations.
May I ask what are the likely causes for this error in the context of this problem? Thank You.
Leviro91 is offline   Reply With Quote
Old   February 17, 2016, 06:01
adrin
adrin is on a distinguished road
You don't say much about the physics of the problem (say, what's the max Mach number, temperature, etc). I would nevertheless venture to guess that your problem is to assume incompressible flow for gases (which are quite likely compressible)
adrin
adrin is offline   Reply With Quote
Old   February 17, 2016, 13:25
Jet
Thnks Adrin! I will try to run it as a compressible flow to see if it solves the problem. I initially ran it as an incompressible flow to compare the differences between compressible and incompressible flow models (That's the essence of my project).
Judging from the initial run with energy off, I would say the max Mach number is ~0.6, which I am aware is in the region where it should be considered as a compressible flow. The temperature at the inlet is 334K. The turbulence model used is the k-epsilon model with enhanced wall treatment.
Review: Reversed flow CRT FLUENT 1 May 7, 2018 06:36
Steady-state flow simulation energy divergence after 1200 cycles JohnnyOnTheSpot STAR-CCM+ 5 May 14, 2015 16:22
Fan simulation divergence ayothicfd CFX 18 July 20, 2012 06:53
Natural convection - Inlet boundary condition max91 CFX 1 July 29, 2008 21:28
Expert parameter to stop the fluid flow simulation KK CFX 1 February 25, 2008 17:29
