Separation efficiency in an straight through cyclone with water
Old   February 9, 2016, 09:00
Default Separation efficiency in an straight through cyclone with water
Cloudseeker is on a distinguished road
Hi all,
I am investigating an axial, straight through cyclone. The fluid is water and the particles are sand with a diameter of around 100 micrometer. The swirl is generated by vanes. The sand should accumulate at the outside wall and being removed with a portion of the water stream. We made experiments with a labor model and a simulation using cfx.
The calculated separation efficiency is around 3 times higher than the measured one. The trajectories match pretty well with matlab calculations. I used RSM and turbulent dissipation for the particles in cfx.
I tried to find some reference papers for the problem. But there is not much information on straight through cyclones, either CFD or experiments. The few actual studies are done with air.
Studies show, that particles tend to accumulate at the edges of eddys. Since these studies were done with air, the effect here with water should be even greater. So it is even possible to get accurate results with the current models ?
Thanks for your comments on my problem.
Best Regards
Jürgen
Ps: Sorry for the bad English.
Cloudseeker is offline   Reply With Quote
Old   February 11, 2016, 05:15
uk
ardismo is on a distinguished road
For 4 months I only work on cyclone seperators. As I see, results are very dependent to URFs ,spatial discretization order and so on. If you can give a little bit more detail maybe I can help you .
ardismo is offline   Reply With Quote
Old   February 12, 2016, 05:17
hi,
The vanes generate the swirl, then the tube tube diameter is reduced to accelerate the flow. then comes a straight tube with an inner tube. The outer diameter is around 0.25 m and the length around 0.7 m. after the tube the outer 4 mm are separated from the rest of the flow.
The average axial velocity in the tube is around 3 m/s and the circumferential velocity is 4.5 m/s. At the inlet the average volume fraction of the particles is between 1*10^-5 and 1*10-3 (different cases). Since the VF increases in some areas i tried it with 1-way, 2-way coupling and 2-way + collisions (4-way). The difference are a few percent points in separation-efficiency, but all are around 3 to 4 times the experimental data.
thank you
Cyclone separation efficiency using CFX Benfa CFX 20 April 9, 2019 14:10
Simulation of rotating undershot water wheel Miss Anna CFX 25 June 8, 2016 00:24
Oil water separation Eric1 CFX 1 September 1, 2010 16:07
Leading edge separation and efficiency KK Main CFD Forum 2 December 3, 2008 07:19
Separation phenomenon of water, droplet and air Raymond CFX 0 July 9, 2004 23:59
