February 7, 2016, 04:34 |
muultiple inlets how to initialize
sandy
Rep Power: 10 |
friends ...
my problem is described as follows 1. rectangular channel, hole at the bottom surface. 2.[ inlet face, hole] both are VELOCITY INLETS. 3. AIR through face inlet, WATER through hole 4 how do i specify volume fraction for both inlets while INITIALIZING |
February 12, 2016, 01:41 |
Rep Power: 13 |
through patching
February 13, 2016, 14:04 |
sandy
Rep Power: 10 |
please care to elaborate, if you might???
February 14, 2016, 01:40 |
Rep Power: 13 |
you can mark, face, regions, volumes etc through adapt->mark.
dont actually adapt the mesh but just mark the region out. next go to initialize->patching select the phase you want to patch, you can patch velocities, volume fractions etc, for the secondary phase you will be able to patch the volume fraction i.e. 1, in the region where there is only water. plot the contours of the volume fraction to see if the patching actually worked. you will be able to see water at the face/surface/region you patched in the contours before actually starting the simulation post back if it worked. goodluck |
February 18, 2016, 16:09 |
sandy
Rep Power: 10 |
Thanks buddyy
why the inlet velocity magnitude differrent from the value i initialize? | eyuhock | FLUENT | 26 | April 20, 2015 21:34 |
Mixture of the same fluid from 2 inlets | godon | Fluent UDF and Scheme Programming | 0 | October 15, 2012 08:04 |
Two pressure inlets problem | Medison | CFX | 1 | August 22, 2012 06:50 |
Multiple Inlets | Charlie V | FLUENT | 0 | May 28, 2001 02:29 |
create Volume with inlets | Roman Bohnes | FLUENT | 10 | December 6, 1999 04:43 |
