Averaging efficiency
Old   February 5, 2016, 06:10
Default Averaging efficiency
David Sauter
David Sauter is on a distinguished road
Hello Everyone,
I have performed an unsteady simulation of a 2-stage axial steam turbine using an in-house solver. Now I am calculating the efficiency using actual enthalpy drop divided by isentropic enthalpy drop. The enthalpy values are given as circumferentially mass-averaged distributions at the inlet and outlet planes, i.e. as radial profiles. Therefore, also the calculated efficiency is in form of a radial profile.
My question is: If I want to calculate a global efficiency, how do I average it properly? Can I just integrate it in radial direction and then divide it by the blade height? Or do I have to use mass-averaging? If so, which mass flow do I use, inlet or outlet mass flow?
Thank you for your answers!
David Sauter is offline   Reply With Quote
average, efficiency, enthalpy, mass-weighted, mass-weighted average
Starting field averaging using libFunctionObject after certain time eelcovv OpenFOAM Programming & Development 25 December 7, 2015 23:28
Axial fan Efficiency Goals calculation? Sanghyun - PARK FloEFD, FloWorks & FloTHERM 1 February 18, 2013 12:20
When to use mass flow averaging cspectre CFX 2 December 6, 2009 06:30
Parelleling Efficiency kassiotis OpenFOAM 0 June 19, 2009 15:12
Averaging LES iko FLUENT 3 July 3, 2008 06:55
