Node-dependent Surface Temperature Fluctuations |
February 1, 2016, 16:43 |
Peter
I'm having a problem with the surface temperatures on the blunt nose of a supersonic vehicle. I'm working with a wedge of an axisymmetric body, using axisymmetry boundary conditions. The surface temperatures along the axisymmetry boundary conditions exhibit and alternating node dependence (this is a node-based solver). For example, one node along the BC is very hot, the next is hot, and then the next is very hot again. And this repeats along the blunt nose. The wall is no-slip. And I am using radiative-convective equilibrium. The temperature variations are nonphysical for the problem and completely node related. Any info or recommendations would be great. Thanks! Peter |
February 1, 2016, 22:27 |
Peter
Some more info which may be pertinent:
This is an unstructured mesh. I am using a Roe scheme It looks like odd-even decoupling, but I've only heard of that occurring on structured grids with CDS... Has anyone seen anything like this before, and how might I get around it? |
node dependence, surface temperature |
UDF for Temperature Dependent Energy Source | er.mkumar | Fluent UDF and Scheme Programming | 9 | March 14, 2024 05:01 |
whats the cause of error? | immortality | OpenFOAM Running, Solving & CFD | 13 | March 24, 2021 08:15 |
[Gmsh] Error : Self intersecting surface mesh, computing intersections & Error : Impossible | velan | OpenFOAM Meshing & Mesh Conversion | 3 | October 22, 2015 12:05 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 23:56 |
creating probe on surface to find temperature | sieginc. | STAR-CCM+ | 2 | June 25, 2012 09:16 |
