January 29, 2016, 09:22 |
Law of the wall with pressure gradient
Tim
Rep Power: 12 |
I know the Law of the wall in turbulent flows (i.e. at flat plate). Is this also valid in decelerated turbulent flows with positive pressure gradient and without separation? Cheers, Schwimmy |
January 29, 2016, 11:54 |
david
Rep Power: 14 |
the law of the wall is based on a constant shear stress under the local equilibrium balance between production of turbulent kinetic energy and its dissipation rate. under adverse pressure gradient conditions, this is no longer valid and some modifications need to be made. this is why the k-epsilon with the standard wall function fails in such flows.
January 29, 2016, 12:17 |
Sushma
Rep Power: 10 |
in this you can apply renyold stress model but it can increase your computation cost
boundary layer flow, law of the wall |
static vs. total pressure | auf dem feld | FLUENT | 17 | February 26, 2016 14:04 |
Rotating Reference Frame Pressure Gradient | clac | FLUENT | 0 | August 22, 2012 19:20 |
Law of the wall in the presence of pressure gradient | yidongxia | Main CFD Forum | 2 | August 5, 2012 15:40 |
Using ideal gas law to simulate pressure decline | Björn Mattsson | FLUENT | 5 | September 5, 2005 05:03 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
