Renormalization Group Method in Turbulence Model
Old   December 16, 1999, 04:42
Default Renormalization Group Method in Turbulence Model
wood
Hi, Can any one explain the Renormaliztion Group Method in a simpler way than a pure mathimatics? Is it the link between the molecular space and the macro space? What is the difference between the RNG and LES?
Thanks in advance!
wood
Old   December 16, 1999, 05:08
Default Re: Renormalization Group Method in Turbulence Model
Jonas Larsson
RNG is a mathematical tool to derive turbulence models. LES is one type of simulation where the larger turbulent scales are resolved (ie 3D unsteady) and the smaller scales are modeled with a sub-grid model. There are LES simulations where people use RNG based sub-grid models. There are also RNG models, for example RNG k-epsilon models, where the RNG model is used for all turbulent scales.
The foundations of RNG are not easy to understand - very mathematical stuff. The big "success" of RNG was when it was shown to reproduce almost exactly the k-epsilon form of equations.
One nice book that contains a few chapters on RNG etc. is McComb, "The Physics of Fluid Turbulence". Also look for papers by Yakhot and Orzag.
Old   January 10, 2000, 20:15
clifford bradford
to understand group theory you'd have to take a very boring and uninteresting graduate math class in abstract algebra. trust me you don't want to do this
Centrifugal Pump and Turbulence Model Michiel CFX 12 January 25, 2010 04:20
turbulence model equation Andy Chen FLOW-3D 4 January 1, 2010 22:45
build your own turbulence model with buoyancy Thomas Baumann OpenFOAM 11 November 23, 2009 09:53
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
