upwind scheme implementation
Old   January 16, 2016, 02:36
Default upwind scheme implementation
Shah
researcher is on a distinguished road
Hi Everyone
I m coding for a case using upwind scheme. I have two rather naive questions regarding that.
Firstly, the convection term, uV. If any upwind method is to be used we have to apply condition what direction is the velocity. In case of flow on an airfoil, does that mean we have to start solution from direction of flow entry? Since initially, inside the domain its all zero velocities. What if the airfoil is moving. Now start solution from where ?
Secondly, do we apply upwind method to both u and V of the convection term ? But upwind scheme assumes u is known with direction !!!
pls guide
regards
researcher is offline   Reply With Quote
Old   January 16, 2016, 04:28
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Originally Posted by researcher View Post
Hi Everyone
pls guide
regards
what you are asking is well described in any textbook of CFD...the upwind is based on the local sign of the velocity component transporting the momentum species. When the velocity is zero, you simply have zero convection...
FMDenaro is offline   Reply With Quote
convection, upwind
First order upwind scheme for stationary continuuity equation with vortices CerpinTaxt Main CFD Forum 8 May 19, 2015 14:25
bounded Gauss upwind Scheme deepinheart OpenFOAM Running, Solving & CFD 1 February 23, 2015 06:57
Implementation of 2nd order upwind scheme jaason OpenFOAM Running, Solving & CFD 4 February 6, 2015 18:40
2nd order upwind vs 2nd order upwind!!! Far Main CFD Forum 7 March 14, 2013 13:29
2nd order upwind scheme (Fluent and CFX) Far FLUENT 0 May 22, 2011 02:50
