Need a help concerning a pure convection problem |
March 14, 2009, 12:14 |
Hello all.
I am studying a book entitled 'An Introduction to CFD : FVM approach' by versteeg. I found two dimensional pure convection problem with discontinuity, and QUICK solver was developed for that problem. However, my code blowed up in the middle of running. I think source term of the discretized equation is so big which cause the system of the discretized equation to be unstable. Is there anyone who have an experience to deal with my trouble? I have a document of the relating equations and numerical descriptions and i can share if leaving e-mail address. Please reply. Regards. |
March 15, 2009, 20:44 |
N/A
Rep Power: 17 |
What was the time marching scheme that was employed ? The explicit schemes have issues with stability. Did you test your code for a simple case like 1-D shock tube problem to check the implementation.
March 15, 2009, 22:26 |
Neo
Rep Power: 17 |
My code use space marching called line-by-line method mentioned in chapter 7 of the book. I think the method may be implicit.
What is your opinion applying line-by-line method with QUICK to pure convection problem? I think my discretized equation applied by QUICK is ok but next step related to line-by-line method is not sure whether is good or bad in this case. Do you have any suggetions to marching method? Now, i'm trying to implement relaxation technique but i can not be sure what results i'll get because the author does not mention in the book which marching method he used. Also i'll consider 1-D shock tube problem. Thank you for reply! |
March 16, 2009, 10:48 |
Neo
Rep Power: 17 |
Thank you for reply.
It doesn't need any pressure correction. The governing equation is as follows. rho*u*(partial phi)/(partial x) + rho*v*(partial phi)/(partial y) =0 And each of face value for 'phi' in FVM is applied by QUICK method and for multi-dimension, line-by-line method is used. That's all. Last edited by 9mile; March 16, 2009 at 11:17. |
March 17, 2009, 06:12 |
Rep Power: 17 |
If it has discontinuities you can use CICSAM scheme.
July 8, 2009, 14:24 |
Nishant Kumar
Rep Power: 17 |
Can someone send me the 1D code for shock tube problem at babuu.nishu@gmail.com? I need it for my research. Thanks alot Nishant |
Very simple natural convection problem | Naseem | FLUENT | 19 | December 17, 2020 17:00 |
Flow is not converging in natural convection problem of boussinesq model for air | rahulsharma | FLUENT | 4 | December 2, 2020 22:07 |
Natural Convection Problem - Helium | marzoa | STAR-CCM+ | 0 | April 18, 2011 15:12 |
Convection & conduction simulation problem | debashis | FLUENT | 1 | June 26, 2009 04:45 |
Natural Convection Problem | Eduardo | FLUENT | 0 | October 21, 2006 15:04 |
