parallel computing
Old   March 13, 2009, 09:51
Default parallel computing
James
hi all, Could someone tell me whether it is possible to run parallel codes on a Core 2 Duo PC, using MPICH on Campaq visual fortran? does it make use of the 2 core processors? thanks in advance!
James
Old   March 13, 2009, 16:57
Default Re: parallel computing
TG
If you can get a Compaq Visual Fortran program to link to some version of mpich then certainly you can run it on Core 2 Duo and it will make use of both cores.
Old   March 13, 2009, 20:09
James
hi, many thanks!
Old   March 21, 2009, 09:47
RenardP is on a distinguished road
You can also use gfortran (Linux, Windows, Mac) or Intel Fortran compiler (this is free only for Linux if I remember correctly).
RenardP is offline   Reply With Quote
Old   March 21, 2009, 09:53
ztdep's Avatar
p ding
ztdep is on a distinguished road
Send a message via Yahoo to ztdep Send a message via Skype™ to ztdep
Originally Posted by TG
;59363
Dear sir:
could you please tell me how to compile a mpich with fortran in windows system.
thank you very much
ztdep is offline   Reply With Quote
Old   March 21, 2009, 11:17
Unhappy The wall in the fluentcan be deleted?and how to remove it
wangyifei
wangyifei is on a distinguished road
Send a message via MSN to wangyifei
I am do not set the faces boundary of wall,but the wall was appeared in the fluent.how to remove the wall in the fluent?
thank you ,your friends fei.
wangyifei is offline   Reply With Quote
Old   March 22, 2009, 07:50
First install mpich on your Windows machine, then read the documentation.
In general it is easier to do CFD on a Linux machine, because you have a lot of free tools (compilers, mesh generators ...).
Old   March 22, 2009, 09:06
Smile OpenMP
Newton KF
NewtonKF is on a distinguished road
Hi Guys,
I've worked with mpich for some time and now I think that openMP is better suited for SMP. It is easier to implement and to use. MPICH is better for DMP and harder to implement.
NewtonKF is offline   Reply With Quote
Old   March 22, 2009, 10:26
TWB
quarkz is on a distinguished road
ya, openmp's easier and better for shared memory. however, i doubt compaq VF can use openmp. I believe intel's ifort can. correct me if i'm wrong.
quarkz is offline   Reply With Quote
Old   March 22, 2009, 11:28
gfortran can use OpenMP on Linux/Windows/FreeBSD.
Old   March 24, 2009, 00:54
leping chen
happy_clp is on a distinguished road
you can use Cilk language.
happy_clp is offline   Reply With Quote
Old   April 14, 2009, 05:21
Red face Re : Parallel computing
  #12
indradi
miko is on a distinguished road
Originally Posted by ztdep View Post
Dear sir:
thank you very much
hi, just wanna share, I did parallel computing on 2 CPUs with 4 Cores in each of them. As I remember, what you need is download the suitable mpich version, install it, target it on your computer path, set your fortran library and link, put parallel command on input data (if needed) and execute it on the command prompt. correct me if its wrong.
miko is offline   Reply With Quote
unchangeable continuity residuals in parallel computing wlt_1985 FLUENT 0 August 1, 2011 13:15
Diffusion equation solved using Parallel Computing Sachin Paramane Main CFD Forum 0 June 12, 2007 00:48
Parallel Computing on Multi-Core Processors Upgrading Hardware CFX 6 June 7, 2007 16:54
Parallel Computing peter Main CFD Forum 7 May 15, 2006 10:53
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 Amitava Majumdar Main CFD Forum 0 January 5, 1999 13:00
