Simulating air injecting to water in a tank?
Old   March 12, 2009, 14:17
Default Simulating air injecting to water in a tank?
Howard Wang
Can any CFD code simulate air injects thru. a tube to water in a tank? I believe this is a problem of fluid interaction or fluid mixing, not multiphase flow.
Thanks, HW
Old   March 12, 2009, 17:06
Default Re: Simulating air injecting to water in a tank?
Hrvoje Jasak
Have a look here - is this what you are after?
http://powerlab.fsb.hr/ped/kturbo/Op...pipeInTank.mpg
This is pretty straightforward 2-phase VOF stuff with a reasonably coarse mesh.
Hrv
Old   March 12, 2009, 18:26
Howard Wang
It is almost there. Additionally pressure loss in air injection may be interested for me.
Thank you very much, Hrvoje
HW
Old   March 12, 2009, 19:08
Model
your water level should rise right after the start of injection because of volume displacement. It does not seem your code is conserving liquid mass...
Old   March 13, 2009, 03:10
Hrvoje Jasak
The water level rises correctly - it's just that the tank has got a z-direction which is larger than what you see in the movie. The code is (of course) fully mass and momentum conservative - it would be quite difficult to write an FVM discretisation that does not conserve mass properly.
There is also a set of experimental comparison data for this case, if you are interested...
Hrv
Old   March 13, 2009, 03:24
Hrvoje Jasak
Let me guess: author with invalid E-mail address, using anonymous relay for posting. Please say Hello to Paul from me.
Hrv
Old   March 13, 2009, 22:32
Ahmed
Fact No 1: A good number of readers of this forum are interested and willing to run OpenFoam on their computers.
Fact No 2: A good number of them cannot even install the programme not to mention run it, for different reasons.
I think there are more negative than positive opinions about OpenFoam.
I guess it would be wise to see why there are angry opinions.
Anyway, I wish not to read harsh sarcastic replies.
FYI
I was able to install and run the programme, but I am not able to finish the first tutorial, I can display the mesh but not the scalar pressure field neither the vectorial velocity field and I do not know why, is there something missing or wrong with my installation, or may be I am not following the correct procedure
problem with two phase flow (air injected in water) miles_davis OpenFOAM 15 March 31, 2021 10:36
Filling Tank with Water leff CFX 7 August 21, 2017 08:47
Simulating air injecting to water in a tank? Howard Wang FLOW-3D 3 March 13, 2009 15:28
Simulating air jet into 2D & 3D water domain Imran FLUENT 0 June 6, 2006 09:57
Simulating Water Splash Using a Particle System Zi-Wei Chiou Main CFD Forum 0 March 4, 2002 07:33
