Symmetry plane for LES in channel
Old   March 10, 2009, 04:59
Default Symmetry plane for LES in channel
Flo
is it possible to use a symmetry boundary for a plane channel LES calculation on the sides or does it influence the development of the flow too much? Would be nice, if someone has an explanation.
Flo
Old   March 10, 2009, 06:59
Default Re: Symmetry plane for LES in channel
Julien
A symmetry plane in this case would essentially act like an inviscid wall. So, the velocity perturbations normal to this boundary will be zero and there will be a region near it where these perturbations ramp up to the expected value. I suppose if the length of your domain in this direction is big enough so that you see a flat region in the boundary-normal velocity perturbation rms and sample for statistics there then you are ok. Why not use periodicity?
Old   March 12, 2009, 04:41
Flo
Thanks for the explanation! Flo
Old   March 12, 2009, 12:40
Joe
You are artificially restricting your flow in the spanwise direction. You have essentially halved the width of your channel. I don't think this is a good idea. In a real flow, the turbulent eddies would be free to cross this plane, so by restricting them you are altering the physics.
Poor Residuals at Intersection Between Symmetry Plane and Airfoil Leading Edge TWaung CFX 2 February 16, 2010 09:11
Symmetry plane help! (with schematic) Nate Siemens 1 October 11, 2007 11:46
Symmetry plane error in solver Santiago Orrego. CFX 6 January 31, 2007 08:09
ICEM and symmetry plane Roland CFX 3 September 13, 2006 09:38
Symmetry plane and force calculation Roland CFX 7 May 31, 2006 14:34
