Coupled flow vs. segregated ?
Old   December 22, 2015, 10:16
Default Coupled flow vs. segregated ?
cfdblender is on a distinguished road
Running an ground vehicle aerodynamic simulation and everything was fine until changed from SEGREGATED flow and energy to COUPLED flow and energy - then every simulation diverged, no matter what I tried (mesh improvements, different turbulence models, etc) ... until I switched back to segregated and it works again.
But why? Could it be the Mach number? (my simulation runs at M=0.175)
cfdblender is offline   Reply With Quote
Old   December 22, 2015, 11:44
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
It could depend on the stiffness for low Mach number....you used a pre-conditioned coupled solver?
FMDenaro is offline   Reply With Quote
Old   December 22, 2015, 12:01
No, not using a pre-conditioned coupled solver? Would the pre-conditioning be done by running another simulation to obtain preliminary some data to configure the solver?
Old   December 22, 2015, 12:09
Generally, the pre-conditioning is performend on the set of equations by changing the state vector.
For example in Fluent:
http://aerojet.engr.ucdavis.edu/flue...g/node1002.htm
http://aerojet.engr.ucdavis.edu/flue...g/node1003.htm
how to turn off coupled energy solver while using coupled flow model feafan STAR-CCM+ 2 July 17, 2014 02:51
Coupled VOF and Multiphase Segregated Flow for a gas bubble problem?? EnronZhang STAR-CCM+ 1 December 19, 2013 09:41
Segregated or coupled solver? Nori FLUENT 0 September 29, 2005 15:24
regarding reacting flow with coupled solver kiran FLUENT 2 April 15, 2005 05:57
segregated flow solver sania FLUENT 1 June 11, 2004 03:11
