rising bubble vof simulation in fluent
Old   December 21, 2015, 07:40
Default rising bubble vof simulation in fluent
vinita
vinita123 is on a distinguished road
Hi
I want to do the rising bubble simulation using vof model of fluent.The system is an air bubble in a stagnant liquid towards the bottom of narrow column.I am having problem in geometry creation using gambit. If anyone has done or knows about this problem please tell me the solution.
vinita123 is offline   Reply With Quote
Old   December 21, 2015, 08:23
Cees Haringa
CeesH is on a distinguished road
This sounds like a relatively simple problem. I assume you want no walls and so, so periodic boundary? Perhaps easiest would be to simply create a box geometry in the geometry editor, and mesh it with hexahedral cells. Or do you have other intentions?
By the way, please post this kind of questions in the FLUENT forum rather than the main CFD forum.
Best
Cees
Last edited by CeesH; December 21, 2015 at 08:26. Reason: this post is in the wrong place.
CeesH is offline   Reply With Quote
Old   December 21, 2015, 08:40
vinita
Thanks for your reply Cees. No i dont want periodic boundary condition i did create the geometry containing three walls and a pressure outlet and did the meshing by using quadrilateral mesh because its a two dimensional problem. The problem is when the mesh is imported to fluent and read,there are some additional walls created and i am not getting the result which I should get.
looking for a smart interface matlab fluent chary FLUENT 24 June 18, 2021 10:07
How to simulate a hull in Fluent using VOF dmaz FLUENT 11 August 4, 2015 15:54
Huge file sizes when Running VOF simulation aarratia FLUENT 0 May 8, 2014 13:27
Simulation for a bubble rising from the bottom of water liguifan OpenFOAM Running, Solving & CFD 9 February 10, 2013 16:42
Fluent Remote Simulation Facility Service (RSF) di Rami FLUENT 2 June 4, 2008 06:38
