colon in Fortran77
Old   December 19, 2015, 16:34
Default colon in Fortran77
jollage is on a distinguished road
I'm writing a Fortran77 code and it would be complied by gfortran or mpif90 (I have gcc 5.2.0 installed). I sometimes used colon for indicating the interested range of an array, is it a good practice for a Fortran77 code? For example, I have
do i=1,Ny
(some subroutine generates a new solu for every i)
a(i,1:Ny) = solu
end do
where a is a 2D matrix of size (Nx,Ny) and solu is a 1D array of size Ny. I tested it and it seems to work good, but I'm concerned with any bug it might generate. The code is much more complicated than these lines. Do you have any suggestions? Thanks in advance.
jollage is offline   Reply With Quote
Old   December 19, 2015, 18:39
flotus1's Avatar
Alex
flotus1 has a spectacular aura aboutflotus1 has a spectacular aura about
That will do. You might as well use
a(i,:)
instead if you do not want to give the lower and upper limits explicitly.
I guess it is just a typo, but I think the first line should read "do i=1, Nx"
Edit:
However since Fortran is column-major, this part of the code might be quite inefficient and it could be a good idea to have the loops for both dimensions of the array explicitly or change their order.
flotus1 is offline   Reply With Quote
Old   December 20, 2015, 15:46
a(i,:)
Edit:
Thanks. I see.
Old   December 23, 2015, 05:05
a(i,:)
Edit:
Can I ask another question? I use gfortran for compiling my F77 scripts. But sometimes I do use intrinsic functions which are introduced for F95 or even later. Will this potentially cause any problems? I did experience that it's of no problem, but need someone to confirm that. Thanks.
Old   December 23, 2015, 05:55
flotus1's Avatar
Alex
I guess only few people out there are still sticking to pure FORTRAN 77 standards.
Gfortran is constantly developing and the features of the newer fortran standards are implemented.
So any recent version of gfortran is able to handle features introduced after the FORTRAN 77 standard. For functions not jet implemented you will get compiler warnings and errors.
fortran77 or 90 hosseinhgf CFX 2 November 26, 2010 02:02
Simulation of a stirred miniplant extraction colon PaMuelle OpenFOAM 0 July 14, 2009 10:17
How can I find a free Fortran77 numerical library? Alberto Main CFD Forum 3 January 21, 2008 01:56
fortran77 help khan Main CFD Forum 3 June 12, 2007 01:24
Fortran77 or Fortran 90 Swapnil CFX 2 November 26, 2002 16:16
