Turbulence mixing length value
Old   February 24, 2009, 12:00
Default Turbulence mixing length value
eva
Dear all:
I am using flow-3d to model the performance of a pile founded deck (an open quay wall) and a slopping beach below it under the action of regular (linear) waves. Regarding the turbulence modelling, the RNG turbulence model is applied.
The Turbulence mixing length (TLEN) should have an appropriate value in order to limit the dissipation so that the turbulent viscosity does not become excessively large.
Are there any reccomendations regarding the selection of the value of TLEN? Should be equal to 7% of the smallest domain dimension or other length scales should be taken into consideration?
If you need any further explanations please let me know.
I would appreciate very much if you can help me on this issue.
Old   February 27, 2009, 15:19
Default Re: Turbulence mixing length value
Harish
Which version of RNG model does flow-3d use ? The one available in the literature by yakhot et al or their own version.
Turbulence length scale and integral length scale rizhang CFX 2 April 22, 2016 08:22
How to define the turbulence intensity and mixing length at an outlet (for k-eps)? david39 OpenFOAM Running, Solving & CFD 6 February 2, 2011 04:01
Discussion: Reason of Turbulence!! Wen Long Main CFD Forum 3 May 15, 2009 10:52
Mixing length turbulence model using Alex FLUENT 2 August 6, 2004 03:19
