February 23, 2009, 16:26 |
Evaporation and condensation in a tube
I am new in Fluent. Can anyone tell me if Fluent can simulate evaporation and condensation of water in a pipe? I would appreciate it if anyone can help me! Thanks a lot!
July 23, 2009, 11:51 |
Fluent's model too simple to be useful
Kuochen Tsai
Rep Power: 17 |
Fluent 12 do have a simple evaporation/condensation model available. However, it is not thermodynamically consistent. The model does not detect vapor go below staturation temperautre and vice versa. So you can get really cold vapor and really hot liquid way beyond the stauration temperautre as specified. A better choice is to use the WET-STEAM model which uses a saturation curve for phase change and should be physically consistent.
September 15, 2009, 22:45 |
muhammad irham mahfud
Rep Power: 17 |
but range temperature for wet steam is 347 to 647, what about if the case is in law temperature, such as evaporation liquid nitrogen?
Regards, Irham |
September 16, 2009, 11:14 |
Wet Steam
Kuochen Tsai
Rep Power: 17 |
Fluent's wet steam model is based on partial pressure but can only be used with density based solver, which can be quite expensive. The evaporation-condensation model is only good for a dilute system. If your case involves lots of other gases with steam, then it is probably ok. For systems with pure steam it won't be able to provde a reasonable answer.
September 16, 2009, 11:19 |
Kuochen Tsai
Rep Power: 17 |
For liquid nitrogen you will need a saturation curve for it. Fluent's wet steam model is only good for water vapor.
Can Fluent perform evaporation and condensation simulation? | Wei Shao | FLUENT | 25 | December 1, 2017 05:12 |
Water Evaporation and condensation modeling | Linjie | FLUENT | 3 | February 6, 2012 14:08 |
Water Evaporation and condensation modeling | Linjie | CFX | 6 | May 24, 2007 15:55 |
A tutorial for condensation or evaporation | Asghari | FLUENT | 0 | September 29, 2006 23:25 |
evaporation and condensation in the VOF model | Glev | FLUENT | 0 | December 24, 2004 05:55 |
