December 7, 2015, 06:22 |
Reliability of 3d urans
anand sudhi
Rep Power: 11 |
Hi
How reliable is the accuracy of 3D URANS. Is it always better to go for LES or DES in 3D cases or is 3D URANS sufficient for calculation of mean quantities like Drag values. |
December 7, 2015, 09:38 |
robo
Rep Power: 13 |
What is the source of the unsteadiness, and what size are your time steps with respect to the larger turbulent fluctuations? URANS is not well formulated as you refine your timestep, and it's accuracy will strongly depend on the character of the unsteadiness you're trying to capture. Note that it also has all the short comings of regular steady-state RANS as well; so if your flow contains strong anisotropy then it would also not be that accurate for example...
3d urans, des, des les, les, urans |
URANS in OpenFOAM | Shaker2000 | OpenFOAM Running, Solving & CFD | 0 | August 9, 2015 08:10 |
Starting a 3D URANS simulation from a converged 2D URANS simulation | Josh | Main CFD Forum | 2 | June 4, 2011 21:32 |
RANS and URANS | dshawul | Main CFD Forum | 0 | February 20, 2011 09:01 |
URANS in ANSYS CFX | brissyben | CFX | 3 | October 6, 2009 18:35 |
URANS and PHANS ?? | gorka | Main CFD Forum | 0 | November 11, 2002 09:12 |
