How is the heat transfer calculated with slip wall condition? |
NY
Rep Power: 10 ![]() |
I am simulating indoor room environment using STAR-CCM+ and trying to use slip wall on the far-field wall. But I don't know how the heat transfer is calculated with slip wall condition. Can anybody help me with it? Many thanks.
#2 | |
Filippo Maria Denaro
Rep Power: 73 ![]() ![]() ![]() |
what do you mean? if the slip condition is consequent to the assumption of inviscid condition, accordingly you have no conducibility in the fluid |
NY
Hi Filippo,
Thanks a lot for your help. By meaning slip-wall condition, I mean the velocity close to the wall is not zero. And in this case, my question is how the heat flux between the wall and air is calculated. What do you mean by "no conducibility"? Meng |
#4 | |
Working with such model drives to the Euler equations and the no-viscosity assumption for the momentum equation is completed in the energy equation by the absence of heat flux (q = - k Grad T = 0) due to the assumption k=0 everywhere in the fluid. |
NY
Hi Filippo,
I'm trying to understand your explanation. But if the heat conduction in the fluid is zero, there will be no heat transfer between the wall and air. Am I right? Many thanks. Meng |
Yes. The assumption for the Euler equation are indeed zero viscosity and zero thermal conductivity.
The first one set no viscous stress the second no heat flux |
NY
But in my case, I only use "slip-wall" condition on the far-field walls. All the other walls are set as "non-slip wall". And I also checked the results, it turned out that the heat transfer through the air is not zero. Many thanks.
#8 | |
h (T- Tp) = - k Grad T |
#9 |
NY
I may not have explained my question clearly. Actually I did not simulate the heat conduction in the wall. I'm only simulating the fluid field with constant wall temperature and slip-wall condition. I know when we are using non-slip wall condition, the convective heat transfer is calculated according to the boundary layer theory and wall function. But if the wall is set as "slip wall". I do not know how the convective heat transfer is calculated. I hope my explanation makes my question more clear. Many thanks.
#10 |
Alex
Rep Power: 49 ![]() ![]() |
For an artificial boundary far away from the region of interest, a symmetry boundary condition is the appropriate choice. For the energy equation this implies that the heat flux normal to the boundary is zero.
The options you have when using a slip wall instead of a symmetry boundary condition depend on the program you are using. We have a CCM+ sub-forum here. ![]() |
slip wall |
external wall heat transfer | ashghan | OpenFOAM Pre-Processing | 16 | October 27, 2015 20:29 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
natural convection | mehrdadeng | CFX | 10 | February 25, 2011 05:25 |
How can I increase Heat Transfer at Domain Interf? | B.Simon | CFX | 3 | October 28, 2008 18:53 |
Convective Heat Transfer - Heat Exchanger | Mark | CFX | 6 | November 15, 2004 15:55 |
