February 17, 2009, 01:24 |
Gambit error creating face
I am trying to create the geometry of an aerofoil with coods. after creating edges to all the vertices, went to the create a face from wireframe. i selected all the edges and i click apply it says -
"ERROR: ACIS error 18016: A face with null geometry created. ERROR: Cannot ceate ACIS frame from wireframe. Turn on the toggle to create planar tolerant face if such a face is required." Y isnt it creatin a face? what is a planar tolerant face? lookin forward to an answer at the earliest. thank you, haridas. |
February 17, 2009, 03:31 |
Re: Gambit error creating face
dont subtract the aerofoil face with the domain face instead do split operation instead of that and delete the aerofoil face and also check all the edges r conected..this would work hari. hope it helps all the best regards hari
[Netgen] Import netgen mesh to OpenFOAM | hsieh | OpenFOAM Meshing & Mesh Conversion | 32 | September 13, 2011 05:50 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 11:55 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues | michele | OpenFOAM Meshing & Mesh Conversion | 2 | July 15, 2005 04:15 |
