How to simulate steam cavitation event CFX
Old   February 12, 2009, 17:27
Default How to simulate steam cavitation event CFX
JRL4444
OK new here so please forgiven any ignorance I let slip into this post. I am interested in the mechanism that drives the cavitation / shock wave event of steam injection into cool water. I am looking for any references as to how to quantify and simulate this event using CFX. My goal is to produce a steam driven oscillating cavitation event. My feeling is that the onset of a steam bubble's energetic collapse could maybe be initiated or at least affected by a pressure pulse. So could one simply build a device that would reflect and focuses a steam induced shock wave back to the steam injection point and achieve high intensity acoustic oscillation?
I have never found a description for what happens to a steam bubble in cold water but my speculation is as follows:
1. Steam cools and condenses on bubble wall reducing pressure in bubble to point of saturated steam. At first inertia keeps water from moving in.
2. Water starts moving in thus pressure in bubble rises and BOOM all saturated steam condenses causing a large vacuum.
OR
2 Water starts moving in and bubble symmetry begins to breakup thus spraying cold water throughout the bubble instantly condensing all vapors causing large vacuum.
Any information related to this subject would be greatly appreciated.
Old   February 13, 2009, 06:46
Default Re: How to simulate steam cavitation event CFX
Bart Prast
Have a look at:
http://caltechbook.library.caltech.e...avbubdynam.pdf
or
http://caltechbook.library.caltech.edu/51/2/cabook.pdf
All fundamentals are there. In principle you can do it with CFX.
Old   February 13, 2009, 14:33
Kylie
this is the best reference available but you'd rather use STAR-CCM+ instead.
[ICEM] Proper way to name boundaries on 2D model for use in CFX? RossFS ANSYS Meshing & Geometry 4 November 10, 2011 03:38
Pros and Cons for CFX, CFdesign, COMSOL Val Main CFD Forum 3 June 10, 2011 03:20
CFX Cavitation Paper Request CFDtoy Main CFD Forum 0 August 27, 2008 14:46
CFX 4.4 installation problem Pandu Sattvika CFX 1 December 1, 2001 05:07
CFD Short Course & CFX User Day Chris Reeves CFX 0 September 11, 2000 09:53
