Adapt o-block to new geometry
Old   November 25, 2015, 15:05
Default Adapt o-block to new geometry
JJ Wey is on a distinguished road
I'm trying to adapt a mesh to a new geometry. At first glance the geometry needed the o-block that can be seen in the image at the right and left, but know the geometry has been changed and simplified. Hence there are extra edges that don't need to be associated to the new geometry. How could I modify the topology or what strategy of association could I follow?
I hope someone can help, I've tried everything I know!
JJ Wey is offline   Reply With Quote
Old   November 25, 2015, 17:24
It's solved now. I did it using the "merge vertices" option which allowed me to reduce the number of edges.
adapt topology, blocking, o-block
[ICEM] Work with imported STL geometry KateEisenhower ANSYS Meshing & Geometry 2 July 9, 2015 11:46
[ICEM] Extremely simple geometry, how to block pyramid in ICEM? sharonyue ANSYS Meshing & Geometry 5 May 15, 2015 12:12
[ICEM] what is the strategy to block this geometry? llrr ANSYS Meshing & Geometry 34 October 18, 2012 09:48
[ICEM] Copy geometry then copy mesh Anna Tian ANSYS Meshing & Geometry 0 July 30, 2012 17:59
[Gmsh] Problem meshing an imported geometry Alicia OpenFOAM Meshing & Mesh Conversion 0 March 30, 2010 05:53
