Mass & Pressure Boundaries
Old   February 5, 2009, 13:37
Default Mass & Pressure Boundaries
kantipudi
Pressure values (total pressure at inlet and static pressure at outlet) of system are calculated initially by using the mass inflow and mass outflow boundaries. Then for the same system, the mass boundaries are replaced with the pressure inlet and pressure outlet boundary conditions (values used are the total and static pressures calculated initially).
Can I expect to get back the mass flow rates with which I started the problem?
Domain Reference Pressure and mass flow inlet boundary AdidaKK CFX 75 August 20, 2018 06:37
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 07:27
Water subcooled boiling Attesz CFX 7 January 5, 2013 04:32
static pressure from mass flow rate mukhtarjussa FLUENT 0 April 12, 2010 11:39
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
