November 21, 2015, 22:31 |
Taylor Maccoll Eq. with Runge Kutta
Yang
Rep Power: 11 |
Before I go use CFD, I wanted to approximate the supersonic flow field after a shock in front of a cone (0 deg. angle of attack). I used 4th order Runge Kutta with Taylor Maccoll eq. and am getting Vtheta = 0 at 31 deg cone half angle when I assume my shock beta = 34 deg. I've stared at my code for 20 h and have manually coded the Runge Kutta eq. as well as using ode45 function and get the same results. My step size is - .001. Can anyone please help? Maybe I'm just braindead...
Apologies if this is the wrong place to ask. |
December 6, 2015, 11:22 |
Yang
Rep Power: 11 |
Nevermind, I found the answer after contemplating for a while... The initial Vtheta used for the Taylor-Maccoll equations must be negative to account for the decreasing Vr due to the flow relieving effect of the 3D cone surface.
April 29, 2021, 14:12 |
Similar Issue
I am having a similar issue. My RK4 is approximating a very high cone angle that is very close to the shock. What did you code your program in? I’m using Matlab. My initial conditions are right, though, so I don’t know what the issue is
matlab code, quasi-2d, runge-kutta, taylor maccoll |
Main advantage of using Runge Kutta of higher order? | jakubstary | Main CFD Forum | 14 | August 20, 2019 16:15 |
rhoCentralFoam Runge Kutta | Henning86 | OpenFOAM Running, Solving & CFD | 24 | December 13, 2016 10:12 |
1D Burgers euqation with 4th Runge Kutta | dokeun | Main CFD Forum | 3 | August 8, 2011 06:34 |
Runge Kutta Optimization | vasanth | Main CFD Forum | 6 | December 2, 2005 13:07 |
Diagonally Dominate Runge Kutta Method | Anthony Iannetti | Main CFD Forum | 0 | January 23, 2001 21:27 |
