Generate fan performance curve using Spalart-Allmaras model |
November 16, 2015, 20:01 |
changhee kim
Rep Power: 12 |
I'm trying to generate fan performance curve using k-e and SA model.
When you see the figure below, (x axis: volume flow rate, y axis: pressure difference) Orange line was predicted by using k-e turbulence model. Blue line was generated by using Spalart-Allmaras model. However, at the low flow rate region, the tendency of two performance curves is totally different! I wonder why this occurs. It has same mesh size, same boundary condition. |
Considering the operating point instead of the fan curve | saisanthoshm88 | CFX | 8 | August 9, 2012 06:57 |
Negative reynolds stresses from Spalart Allmaras model | velezisaza | OpenFOAM | 0 | October 15, 2010 05:49 |
Numerical integration of Spalart Allmaras turbulence model | RenardP | Main CFD Forum | 0 | June 11, 2009 14:53 |
About Spalart Allmaras Model | SUNIL | Main CFD Forum | 0 | December 2, 2005 06:23 |
Spalart Allmaras Turbulence model - Need article! | CFD Student | Main CFD Forum | 0 | December 27, 2004 04:28 |
