November 15, 2015, 08:02 |
Blunt/sharp trailing edge
Morteza
Rep Power: 16 |
Hi
Please somebody tell me what is exactly the differences between an open TE vs. closed TE? I mean which one will lead to better results. I am going to model airfoil with moving mesh. |
November 18, 2015, 12:35 |
Matt
Rep Power: 18 |
what do you mean, 'yield better results'? airfoils are either designed with a blunt TE or a sharp TE.
I wouldn't truncate an airfoil to get a blunt TE if it has sharp TE based on coordinate data then try to compare it to experimental results. |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 07:09 |
Trailing edge sensitivity anlaysis | JanH | SU2 | 2 | November 23, 2018 14:53 |
[ICEM] Hole near sharp trailing edge of airplane/wing geometry | jlichtwa | ANSYS Meshing & Geometry | 2 | September 21, 2010 16:19 |
Which trailing edge is correct for meshing of aerofoils for CFX | LSC | CFX | 0 | May 10, 2009 13:45 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
