November 12, 2015, 15:13 |
Converge solution for Wall film Model
Rep Power: 11 |
I am running two-phase simulation with Euler-Lagrangian simulation where secondary phase is tracked via lagrangian calculation. As droplet hitting wall, I use Eulerian Wall Film theory. All simulation is run in transient state. However, I wasn't sure how do I dictates that the solution for wall film is converged and steady (FLUENT). Thanks Kind Regards, Jee Loong |
November 13, 2015, 16:20 |
Sarang
Rep Power: 11 |
What kind of a problem are you solving ?
1. Is your Lagrangian particle source periodic (fuel injector) or sequential (one time only) 2. Do you use any kind of film vaporization model ? |
November 18, 2015, 12:13 |
Rep Power: 11 |
Dear Sarang V,
Appreciate for your response. I am running continuous injection of particles into a duct domain and upon hitting the wall it forms film. It is not runs on periodical timing like fuel injector or sequential (one time like spray) No there is not vaporization model applied to remove the mass as I assumed that the wall temp is well below boiling temp of liquid. And the oil droplet enters from surface injection at normal average temperature probably 30 celcius. Thanks Regards, Jee Loong |
November 18, 2015, 12:34 |
Sarang
Rep Power: 11 |
Ok, In that case I would just look at a plot of film mass vs time and overlay the total fuel mass for reference.
Does anyone use the eulerian wall film model ? | spaghetti | FLUENT | 1 | July 24, 2015 10:31 |
solution convergence and mesh density in k-omega model (FLUENT) | ripong | FLUENT | 0 | January 29, 2015 18:09 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 15:32 |
k-omega turbulence model: 1 vs 2 order solution | Manucia | FLUENT | 0 | August 31, 2009 15:57 |
Wall functions | Abhijit Tilak | Main CFD Forum | 6 | February 5, 1999 02:16 |
