November 12, 2015, 10:17 |
Option Frame Motion
NNM_BSP
Rep Power: 11 |
Dear all,
With design modeler and mesh I made a pipe. Now I want to rotate this pipe around a parallel axis. This rotation axis lies 16 mm away from the center of the tube. I use the option frame motion for this and define my axis origin and rotation-axis direction.The problem is that I don't seem to get the velocity profile that I would expect. Is the frame motion option the correct feature to do this? Someone gave me these tips, but I don't really know what to do with them.. - rotating part as static part in the rotating frame - static part as moving part with a 0 velocity in the absolute reference frame. Hope somebody can help me with this Kind regards |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
particle tracking | sakurabogoda | CFX | 7 | December 4, 2013 23:12 |
