coupled equations: prediction correction method |
Morocco
Rep Power: 11 ![]() |
Dear all,
I have used a predictor corrector method to solve unsteady two coupled energy equations, discretised with an implicit scheme. Actually, the solution converge to steady state when the total time is high enough, but the problem is that the temperature distribution differs when I change the time step! for example for the same total time of 1000sec, I have different results for a time step=1; 10; 100. with a relative difference of about 0.3-8% from dt=1 to dt=100. Is the explicit predictor corrector method affecting the stability of the implicit scheme? Thanks in advance. |
cfd, coupled equations |
Convergence criteria for pressure correction method solving Unsteady N-S equtions | o_mars_2010 | Main CFD Forum | 6 | March 10, 2013 05:46 |
Solving coupled equations | challenger149 | Main CFD Forum | 0 | June 6, 2012 03:11 |
free surface bc using pressure correction method | Sal | Main CFD Forum | 0 | March 10, 2007 15:50 |
pressure driven flow by pressure correction method | justentered | Main CFD Forum | 0 | December 29, 2003 23:52 |
Unstructured Multigrid Method for Euler equations | Jian Xia | Main CFD Forum | 8 | December 20, 1999 12:31 |
