Incompressible vs compressible solvers
Old   January 18, 2009, 14:32
Default Incompressible vs compressible solvers
James
I have to model an internal flow situation where the Mach number varies from 0.03 to 1.2. I have a compressible flow solver at hand. I'm wondering whether a compressible solver can solve the flow even if I have very low Mach numbers?
I was told that I could re-scale my geometry so that I can have a higher Mach number and the re-scaling would a lower Re.
Cheers
Old   January 18, 2009, 17:00
Default Re: Incompressible vs compressible solvers
otd
Not sure I understand:
If you change the geometry in the compressible solver (CS) in such a way that you change the velocity field, that would change the Mach number field. The Reynolds number has velocity and a geometry dimension in it - so Re might go up or down depending on what was changed in what direction.
It might be more useful to set up the same geometry in both compressible and incompressible codes - if both codes are well-understood and checked out.
Some of the older Los Alamos codes (sola-ice comes to mind) would work at low Mach numbers.
Hope this is of some use to you.
Old   January 18, 2009, 20:39
Harish
The compressible flow solver would work fine at the lower mach number range if you have preconditioning implemented in the compressible solver. You rescale the wave speeds to achieve this.
Old   January 19, 2009, 00:32
momentum_waves
What about viscous stresses? If the solver is based on Euler equations & not Navier-Stokes, you're going to be solving for the wrong physics. Surely?
mw...
www.adthermtech.com/wordpress3
Old   January 19, 2009, 06:07
James
Sorry I meant rescaling the geometry and using a higher Mach numbers so that the Reynolds number still remains constant (if that makes sense). Will this be valid?
Old   January 19, 2009, 06:15
Timon
No. For flows to be dynamically equivalent, both Reynolds and Mach number need to be the same!
compressible and incompressible flow chinababu FLUENT 4 November 13, 2008 06:56
Can a compressible solver solve incompressible ? jinwon park Main CFD Forum 17 December 13, 2007 06:00
Compressible -> incompressible. Jinwon Main CFD Forum 6 November 23, 2007 22:07
NS-incompressible and compressible flow solvers ag Main CFD Forum 2 September 27, 2005 07:18
Compressible vs. Incompressible formulations Fernando Velasco Hurtado Main CFD Forum 3 January 7, 2000 17:51
