January 12, 2009, 00:37 |
Pressure relief valve
We are doing some testing on pressure relief valve for pressurized oil. Our test engineer reported the heating of the PRV during operation. I am surprised since there should be cooling during the release of the pressurized oil. As the process is very fast and we assume it is adiabatic it is a case of adiabatic cooling. Isn't it?
Your explanation will help me to understand the process. Thanks |
January 12, 2009, 08:40 |
Re: Pressure relief valve
I assume the pressurized oil is (almost) incompressible. So there is no real cooling as with a compressible gas undergoing an adiabatic expansion. When the oil contains dissolved gas which is released during depressurization this will have a slight cooling effect. But when dealing with an incompressible fluid you will get heating due to friction.
January 13, 2009, 00:06 |
Thanks Bart for the explanation. I will dig into it further.
Fluent natural ventilation pressure boundary condition | pierresandre | FLUENT | 24 | November 8, 2011 14:32 |
How to simulate valve using pressure BC?? | Luk_Fiz | CFX | 4 | August 16, 2010 18:27 |
Pressure enigma. | Sara | Main CFD Forum | 22 | July 30, 2009 04:46 |
Neumann pressure BC and velocity field | Antech | Main CFD Forum | 0 | April 25, 2006 02:15 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
