Shell and tube heat exchanger
Old   October 23, 2015, 02:03
Default Shell and tube heat exchanger
Nitish Amnerkar
nitish_a is on a distinguished road
I want to analyse the shell side of the shell and tube heat exchanger. For that I need outlet temperature and pressure drop and total heat transfer rate. I have done the meshing and my solution is converged. How do I calculate these values in Ansys fluent
nitish_a is offline   Reply With Quote
Old   March 31, 2016, 08:13
Default Obtain solutions using Report tab>Surface flux
Nemish
Nemish is on a distinguished road
Since, your solution is converged, i think you are asking how to obtain evaluated values. Go to Report tab for the same. for h, use mcdelT=hAdT, to obtain average value
hope this helps
Nemish is offline   Reply With Quote
How to carry out 3D shell and Tube Heat Exchanger analysis in fluent medogalal FLUENT 3 December 30, 2015 05:28
Error in CFX Solution for Shell and Tube Heat Exchanger Shomaz ul Haq CFX 3 October 13, 2015 11:49
shell and tube heat exchanger... ganesh chakravarthi CFX 3 July 6, 2015 19:44
Analysis of shell and tube heat exchanger in Ansys Dena FLUENT 0 June 12, 2015 14:39
shell and tube heat exchanger samidabest FLUENT 0 January 8, 2013 04:26
