Stream function from known velocity
Old   December 17, 2008, 10:15
Default Stream function from known velocity
Beginner
Hi all,
I wonder if someone can give me some hints, or even links, to how to calculate stream function if the velocity field is known. (for 2D flows) Well, I know that numerical integration is feasible but it is really appropriate?
Thanks in advance
Old   December 17, 2008, 11:36
Default Re: Stream function from known velocity
Jonas Holdeman
If you use the finite element method, here is a suggestion. I suppose we are talking 2D. Use a scalar element for the stream function. Its DOFs are the stream function at the nodes. Construct a new velocity element from this by taking the curl of the shape function. The result is a divergence-free element, but the DOFs are still stream function. Do a least-squares fit of this velocity element to your velocity data. The resulting nodal values will be what you want, and the SF element interpolates them.
I suppose you could use any appropriate Lagrange FE, but I use Hermite FEs. In fact, I use the curl of modified Hermite elements to calculate my velocities in the first place. Note that in 2D, the gradient is [d/dx, d/dy]^T while the curl is [d/dy, -d/dx]^T. They differ by an interchange and a change in sign. So the modification I mentioned is to interchange the first derivative DOFs of the Hermite element and change the sign of the appropriate one. Then take the curl, and you have a vector element that is divergence-free with divergence-free DOFs plus the stream function. Use this to calculate the velocity and you get the stream function as a bonus.
A useful Hermite element can be found on P179 of Zienkiewicz, 1971 book "The Finite Element Method in Engineering Science". There are a number of other Hermite elements, derived for plate-bending problems.
Old   December 17, 2008, 11:45
Beginner
Basically I use FE but also FD. So your solution seems feasible to be integrated in my FE code. Thanks a lot. However, I develop also a FD code, so if someone had a solution in FD it'll be much appreciated.
Cheers
Old   December 17, 2008, 13:18
Ananda Himansu
If your scheme conserves numerical fluxes (as would a finite volume scheme, for example), then you might consider what I described in a post yesterday:
"Re: plot streamline" Tue, 16 Dec : http://www.cfd-online.com/Forum/main.cgi?read=63716
It is cheap, and will give reasonable results.
However, if your scheme is not conservative, then Jonas' suggestion of least-square fitting would ensure equality of mixed partials while best approximating both components of velocity. Although I am not sure what Jonas means by the curl of a scalar.
Old   December 18, 2008, 15:51
Jonas Holdeman
The stream function in 2D is the z-component of a vector potential. By the curl of a scalar, I mean the curl of a vector with a single (z) component. curl(psi)=[d(psi)/dy, -d(psi)/dx]^T, i.e. curl(psi)=[u, v]^T, u=d(psi)/dy, v=-d(psi)/dx.
Old   December 18, 2008, 20:01
Ananda Himansu
oh, okay, thanks, Jonas. Yeah, I recall now the vector aspect of the streamfunction in Karamcheti's Ideal-Fluid Aerodynamics ...
Old   August 16, 2009, 13:24
Default velocity vector, streamline and stream function
Hussam
Hussam is on a distinguished road
Dear Sir
My name is Hussam Ali Khalaf, postgraduate student in Iraq and Am currently working on “A Solution Algorithm for Transient Fluid Flow with Multiple Free Boundaries”
I have results for velocities values (u and v) in directions x and y for undular bore evolution (please, note the file attachment), rectangular uniform mesh (2Dimension, (i,j)=(22,10)) consists of 20 cells in the horizontal direction (length=12 , ∆x=0.6) and 8 cells in the vertical direction (height=1.6, ∆y=0.2).
Am supposed to draw velocity vector, streamline and stream function . I have a program TecPLOT, I have tried several times but I don’t fully understand how TecPLOT reads the results, would you please help me if you have any idea on how to go about it.
Thank in advance
Yours sincerely
Hussam Ali Khalaf
Iraq
Hussam is offline   Reply With Quote
Old   September 2, 2009, 10:44
Default Stream function from known 2d velcity field
Eric
eric2000 is on a distinguished road
Hi all,
I have a 2D velocity field (u,v) along with their spatial coordinates. I appreciate if I get any code to compute the stream function from the known velicty.
Thanks,
Eric
eric2000 is offline   Reply With Quote
Old   September 2, 2009, 11:02
David P. Schmidt
schmidt_d is on a distinguished road
All:
Is there some reason that you all are not using the standard OF utility, streamFunction ?
foam@cobia:~/OpenFOAM/OpenFOAM-1.5-dev/applications/utilities/postProcessing/velocityField> streamFunction -help
| \\ / O peration | Version: 1.5-dev |
| \\ / A nd | Revision: 1345 |
| \\/ M anipulation | Web: http://www.OpenFOAM.org |
Usage: streamFunction [-noZero] [-case dir] [-parallel] [-constant] [-latestTime] [-time time] [-help] [-doc] [-srcDoc]
-David
Originally Posted by eric2000 View Post
Hi all,
Thanks,
Eric
schmidt_d is offline   Reply With Quote
Old   September 2, 2009, 11:11
Eric
first my operating system is Windows. OpenFoam is Unix based.
Originally Posted by schmidt_d View Post
All:
-David
Old   September 26, 2018, 13:49
A. Min
alimea is on a distinguished road
All:
-David
dear David
I'm working on flow around a cylinder in an open domain (the boundaries are not wall except cylinder).
I need stream function to plot streamlines. can I use this utility?
could you please give me the command to do that?
thanks
alimea is offline   Reply With Quote
A girl fail to plot velocity profile when mesh changes + Wall function asherah STAR-CCM+ 0 February 19, 2010 18:45
latest OpenFOAM-1.6.x from git failed to compile phsieh2005 OpenFOAM Bugs 25 February 9, 2010 05:37
Compilation errors in ThirdPartymallochoard feng_w OpenFOAM Installation 1 January 25, 2009 07:59
Problem with compile the setParabolicInlet ivanyao OpenFOAM Running, Solving & CFD 6 September 5, 2008 21:50
Stream function in Star-CD DenizeN Siemens 0 September 20, 2006 04:48
