Flow through multiple holes
Old   December 16, 2008, 10:01
Default Flow through multiple holes
Matthew Markham
Not sure if you can help me but here is my question.
I am looking for a basic model CFD or otherwise to model/understand the effect of fluid flow through multiple holes. The problem is I have reservoir of gas which then goes into a chamber through multiple holes and I am interested in how the different holes interact with each other e.g. how the size of the holes and the spacing of the holes effect the behaviour of gas flow into the chamber. I am looking for some code or even a basic empirical model to understand this. I appreciate that an exact solution to this problem will depend on geometry but I just want to understand general trends e.g. a some point when the holes are widely separated they will act as single holes whereas when you bring them closer together then they will start to behave as one.
Thanks for your help in advance.
Matthew
Old   December 16, 2008, 13:44
Default Re: Flow through multiple holes
mettler
multiple holes in a series?..or a perforated plate?
Old   December 30, 2008, 02:35
Benarji
You can use 'Porous Media' approach. With this approach you can see the behaviour of the gas by varying size of the holes as well as gap between holes.
Old   January 28, 2009, 22:47
Josh
Hey I was wondering if you found out the relationship between an x amount of holes of various diameter sizes and the flow rate coming out of the holes. -Josh
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Multiple Fluid Flow Brian_Pal FLUENT 8 January 28, 2010 13:49
transform navier-stokes eq. to euler-eq. pxyz Main CFD Forum 37 July 7, 2006 09:42
Multiple Flow. Tom CFX 2 February 25, 2006 23:40
Multiple flow outlets rahul FLUENT 2 October 28, 2002 03:03
