December 11, 2008, 07:44 |
Segmentation fault with parallel computing
Hi All,
I am solving my velocity field and velocity dependent scalar field. My in house CFD code is running fine with single processor. But same code is terminating with segmentation fault, on parallel computing. If I don't call my scalar routine then it is running very fine on parallel processors. I am using MPI for parallelization. Can any body suggest what i can check for this or what can I do? Thanks Prad |
Segmentation fault when running dieselFoam or dieselEngineFoam in parallel | francesco | OpenFOAM Bugs | 4 | May 2, 2017 21:59 |
Segmentation fault in interFoam run through openMPI | voingiappone | OpenFOAM | 16 | November 2, 2011 06:49 |
Segmentation Fault when using class based on KinematicParcel in parallel | gschaider | OpenFOAM Bugs | 1 | August 18, 2008 06:18 |
Fluent parallel: segmentation fault? | hp | FLUENT | 2 | September 6, 2001 14:18 |
Parallel Computing Classes at San Diego Supercomputer Center Jan. 20-22 | Amitava Majumdar | Main CFD Forum | 0 | January 5, 1999 12:00 |
