Using a Mass Flow Rate profile with a Temporal field as a Boundary Condition
Old   October 18, 2015, 10:25
Default Using a Mass Flow Rate profile with a Temporal field as a Boundary Condition
Jotheman is on a distinguished road
Hello guys
I want to use a mass flow rate profile with a time filed as the input boundary condition in CFX. The flow is too complex for CEL so that is out of the question. I have not seen an example of this being done in CFX before. I have however a template with spatial xyz field and corresponding velocity and Total pressure fields specified.
The data file I have has time in one column and mass flow rate in the second column and there are 720 points in total. I want to use that for a transient flow analysis through a pipe connected to a turbo machine.
I would like help creating the csv file to allow this to happen unless there is another method.
Thanks
Jotheman is offline   Reply With Quote
Setting mass flow rate boundary condition maysmech OpenFOAM 15 July 22, 2021 12:30
Total pressure and mass flow boundary condition at inlet bscphil OpenFOAM Pre-Processing 3 July 9, 2017 15:39
Waterwheel shaped turbine inside a pipe simulation problem mshahed91 CFX 3 January 10, 2015 12:19
Radiation interface hinca CFX 15 January 26, 2014 18:11
Mass flow rate boundary condition for continuity equation for oscillating flow p07ip705 Main CFD Forum 0 February 28, 2013 02:33
