Singularity in two fluid model (Eulerian-Eulerian)
Old   December 7, 2008, 03:01
Default Singularity in two fluid model (Eulerian-Eulerian)
Zak
In the Eulerian two-fluid model for two-phase flows, the standard formulation for the momentum equations becomes singular as the volume fractions tend to zero. Some papers suggest that resulting velocities can fluctuate widely in the regions where volume fractions tend to vanish.
How do you deal with the problem of singularity in your code?
Or could you give me some effective suggestions for the problem or references about Eulerian-Eulerian Model?
Thanks!
Old   December 8, 2008, 02:39
Default Re: Singularity in two fluid model (Eulerian-Euler
vadim
single phase or decoupled phase formulation is an effective method, you can get idea from immersed bc methods e.g. see: Hao & Prosperetti JCP 2004, or sharp interface cartesian method by S. H. Udaykumar in JCP
a commnet: you can use variable density formulation, e.g.
rho = vol_frac * rho_flo + (1-vol_frac) * rho_virtual
ratio = rho_flow/rho_virtual
ratio >> 1
Old   February 27, 2010, 06:35
Claus Meister
idrama is on a distinguished road
Hello vadim,
you said "velocities can fluctuate widely". Could it be that during the simulation the time steps becomes smaller and smaller. My question based on the a problem i have. My simulation runs between 0s and 0.6 s, and in time of 0.18s simulation time the time steps, which are dependent on CFL number (bounded by 0.5), getting smaller and smaller and evetnually the simulation abords.
cheers,
idrama is offline   Reply With Quote
Old   February 27, 2010, 06:36
Claus Meister
Furthermore, should our problems be related then I want changes my question: how can i avoid it?
Old   February 28, 2010, 18:54
Default reference
CFDtoy
CFDtoy is on a distinguished road
Hi there,
Could you kindly post your reference where they indicate as alpha -> 0, vel -> high values?
Thanks,
CFDtoy
Originally Posted by Zak
;58123
Thanks!
CFDtoy
CFDtoy is offline   Reply With Quote
Concentric tube heat exchanger (Air-Water) Young CFX 5 October 7, 2008 00:17
Mixture and Eulerian Model Hassid S. FLUENT 1 August 9, 2007 08:24
Eulerian Model Hassan FLUENT 2 September 7, 2006 08:17
the interface bc in Eulerian Model lily FLUENT 0 July 28, 2005 03:37
Two phase Eulerian Model Problem senthil FLUENT 5 May 21, 2003 03:55
