k-e model limitations
Old   December 5, 2008, 02:36
Default k-e model limitations
Prashant
Hi ,
I am facing convergence problem while simulating one case with k-e model.Are there any limitations of k-e model?
Prashant
Old   December 5, 2008, 15:43
Default Re: k-e model limitations
Pratik Mehta
Actually it would be much better if you could specify ,what kind of simulation ,you trying to do .
thanks
Old   December 5, 2008, 23:37
Prashant
Hi Pratika,
I am studying velocity distribution in a room having diamensions 9 m lenght 3m height and the room has about 20cm opeing at top for inlet and and about 15 cm opening at bottom for the outlet.
Old   December 8, 2008, 10:03
Pratik Mehta
Is your system a forced convection or natural convection , What are you interested to obtain or what is the final goal of your simulation
Thanks for sharing info
limitations of k-epsilon-turbulence model jet Main CFD Forum 3 January 20, 2010 12:26
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 26, 2009 00:27
help for different between les model (subgrid-scale model) liuyuxuan FLUENT 1 October 2, 2009 16:25
Grid resolution for full-scale and down scaled model gravis Main CFD Forum 0 October 2, 2009 11:27
Advanced Turbulence Modeling in Fluent, Realizable k-epsilon Model Jonas Larsson FLUENT 5 March 13, 2000 04:27
