ansys to investigate deflection of wing
Old   December 1, 2008, 13:24
Default ansys to investigate deflection of wing
xuefeng
im currently tryin to start on my project which requires mi to use ANSYS to investigate the deflection of 3D wing in steady state flow while varyin the different dimensions of the winglet. do i use flotran for this case? any examples to guide mi along? im very new to ANSYS...thanks alot!
Old   December 1, 2008, 20:16
Default Re: ansys to investigate deflection of wing
Ahmed
Start here http://www.mece.ualberta.ca/Tutorials/ansys/index.html
Old   December 2, 2008, 01:09
xuefeng
hi! thanks for the link...but actually i've went thru tat website b4 but i cant find one tat uses a fluid flow..i've done the basic strain on structure kind of problems b4, but 1st time tryin with fluid flow..so was wondering if flotran is needed...
thanks!
Old   December 2, 2008, 17:13
Ahmed
see the installed help system for two tutorials using flotran
Making wing geometry in Ansys 12.1 akash_morar ANSYS Meshing & Geometry 3 September 26, 2013 15:46
Forward swept wing simulation abid Siemens 1 June 16, 2012 14:26
FSI, Fluent Ansys coupling Greg Carnie FLUENT 5 January 7, 2010 20:15
Exporting results from CFX to ANSYS ?? sohail ahmed CFX 1 December 20, 2007 02:10
Source file to compute wing deflection Jerry Main CFD Forum 0 January 7, 2004 01:55
