How can I calculate momentum efflux from boundary data of a 2D nozzle?
Old   October 11, 2015, 15:49
Default How can I calculate momentum efflux from boundary data of a 2D nozzle?
gautham narayan
gauthamnarayan is on a distinguished road
I am trying to calculate the momentum efflux(N/m) from a 2d axis-symmetric case of a CD nozzle. I have the U,V momentums and pressure data. I have tried to use trapezoidal rule to line integrate the momentum at the exit. This is resulting in extremely low values. There might be an error in the variables I am integrating.
Can someone please guide me as to how I could calculate the momentum efflux from the boundary data of a 2D case.
gauthamnarayan is offline   Reply With Quote
Old   October 11, 2015, 17:17
Filippo Maria Denaro
FMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura aboutFMDenaro has a spectacular aura about
Given the total momentum flux (rho vv + p I + 2 mu Grad v ), you just project it along the normal unit vector to the exit boundary and you get a vector flux having x and y components. Now you can integrate along the exit line using the trapezoidal rule. Of course, the solution must be accurate
FMDenaro is offline   Reply With Quote
Old   October 12, 2015, 01:01
gautham narayan
Dear sir,
I have the UMomentum from the solver. I have tried to integrate \int Pdx using the trapezoidal rule. If this is correct, then I have a fundamental doubt. Please bear with me as it may seem obvious.
The units of momentum efflux is N/m. which I have understood as Force/unit length of boundary. But,
Force = Momentum/Time
Please can you explain how integral of momentum with length, gives a result in N/m.
Thank you very much.
Old   October 12, 2015, 04:16
Dear sir,
As you see, the momentum flux has the dimension of the pressure (N/m^2) therefore just a line integration gives dimension (N/m)
Old   October 18, 2015, 12:13
Lucky
Are you working in cartesian x,y,z or cylindrical coordinates? And are you off by a factor of 2pi? If it's a 2D axisymmetric then the integral should be over \int ()dA or \int ()rdrdtheta, or \int ()rdr and multiply by 2pi. But you still need to weight the integrand by r.
Old   October 26, 2015, 08:15
gautham narayan
Sorry to reply late.
I am using a cartesian coordinate system. I was actually of by a huge factor. Anyways I was able to solve it. Turns out i was supposed to also multiply it with velocity.
This particular solver outputs momentum as rho*u and not rho*u*u.
So actually i was ending up with mass flow integral and not that of momentum efflux.
Thanks for your reply.
Old   October 26, 2015, 21:32
Lucky
That's great. I guess as a final note for others that might read this thread in the future I'd like to point out:
If you are talking about a particular fluid particle at a given location r(x,y,z) then rho*u is the momentum of the fluid particle at that location. So it is correct to say that rho*u is the momentum of a fluid particle.
The confusion is when you integrate fluxes through an area element dA, there is a dot products of the velocity vector with the area vector dA. i.e. mass flux is the integral of simply rho, the rate of efflux of mass density is mass flux which is then the product of rho with the dot product of u and dA. It's important to differentiate what is the property being advected (rho for mass, rho*u for momentum, rho*h for enthalpy) and the rate at which it is being advected (u dotted with dA).
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source silvan CFX 3 June 16, 2014 10:49
Modeling interface of fluid and porous, not with default setting ftab CFX 27 May 20, 2014 07:58
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
How to update polyPatchbs localPoints liu OpenFOAM Running, Solving & CFD 6 December 30, 2005 18:27
