November 24, 2008, 06:16 |
Multi-block grids references
I'm making a multi-block structred grid of an aerofoil with deployed slat and flaps. Any one know of some good references for this? Normally, I'd make an unstructred grid but a multi-block structred has been requested. My main concern is making blocks around the high-lift devices as they are close to the main aerofoil section. Thanks. |
November 28, 2008, 01:48 |
Re: Multi-block grids references
Yes,I can do this.May I help you?
November 28, 2008, 03:20 |
References for the finite volume method on unstructured grids | old newbie | Main CFD Forum | 1 | April 26, 2011 00:53 |
coupling and multi block meshing | abdullahkarimi | Siemens | 1 | November 11, 2010 03:20 |
[Commercial meshers] Icem Mesh to Foam | jphandrigan | OpenFOAM Meshing & Mesh Conversion | 4 | March 9, 2010 03:58 |
Multi Block case. | Constantinos Constantinou | FLUENT | 1 | October 26, 2001 03:00 |
F90, modules and multi block | Frank Muldoon | Main CFD Forum | 0 | October 13, 1999 23:37 |
