Air flow over a cylinder - what regime?
Old   November 17, 2008, 21:33
Default Air flow over a cylinder - what regime?
momentum_waves
Air flows over a cylinder in a 2D domain.
What flow regime can we consider the fluid to be in, with a Reynold's number of 1100 relative to cylinder diameter, domain entry velocity & air kinematic viscosity?
Would a clear fluid structure flow pattern be expected, behind the cylinder? Would this flow pattern be distance-dependent relative to the cylinder?
mw...
<www.adthermtech.com/wordpress3>
Old   November 17, 2008, 23:04
Default Re: Air flow over a cylinder - what regime?
Ahmed
Please Check this study http://www.grc.nasa.gov/WWW/wind/val...l/lam_cyl.html in this paper results for Re=100-2000 are given http://www.mate.tue.nl/mate/pdfs/889.pdf some nice pictures http://www.eng.fsu.edu/~shih/succeed...m#Introduction http://amath.colorado.edu/faculty/fo...0_Fl_p_cyl.pdf
Old   November 18, 2008, 00:01
momentum_waves
Hi Ahmed,
Thanks for those very interesting links - you are a true goldmine of useful information.
Now, to re-visit the original question (slightly extended):
With 'do-nothing' boundaries on top, bottom & exit (flow in a freestream), with a Re~1100, what regime would we characterise the flow to exist in - laminar, transition, turbulent, fully-turbulent?
What would the flow field look like in the L/D range of 20-40?
mw...
Old   November 18, 2008, 00:04
Default Addition: Air flow over a cylinder - what regime?
momentum_waves
mw wrote: What would the flow field look like in the L/D range of 20-40?
where: L = distance behind cylinder D = cylinder diameter
mw...
Old   November 18, 2008, 00:42
Default Re: Addition: Air flow over a cylinder - what regi
Ahmed
Right now, what I can say is that it is unsteady flow (vortex shedding on the down stream side). There is a nice FLUENT tutorial, I have it in paper form, but if you google you might be lucky, you can find the whole documentation on some University sites, I am inclined to say at this Re the flow is turbulent, but I have to check some old notes before. There is a reference to an article mentioned by Jed few days ago http://www.cfd-online.com/Forum/main.cgi?read=62578 referring to the No Boundary condition instead of the classical outflow BC so please check it, and good luck
Old   November 18, 2008, 02:07
momentum_waves
Thanks Ahmed. Could I respectfully ask you to forward a copy of the paper to my e-mail address? Many thanks.
I've been using the 'do nothing' or 'no boundary' condition for years. In most flow problems it makes sense to not impose constraints (boundaries) where none exist in nature - especially if we wish to observe a natural flow event.
mw...
Old   November 19, 2008, 13:08
momentum_waves
Any further ideas on what flow regime we are working with?
mw...
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
flow over a cylinder urgent! kevin FLUENT 8 August 11, 2015 14:00
Ansys Fluent UDF - for Data Center Air flow management kedarjan Fluent UDF and Scheme Programming 13 November 13, 2013 05:20
Flow induced vibration of a mobile cylinder Hooman Main CFD Forum 0 December 31, 2010 09:48
Two-phase air water flow problems by activating Wall Lubrication Force challenger85 CFX 5 November 5, 2009 06:44
