rotating control point
Old   September 29, 2015, 10:54
Default rotating control point
Ava
AvaShahrokhi is on a distinguished road
Hi everybody,
I am working on a vertical axis wind turbine and I wish to export data in a couple of regions adjacent to the blades. Since, I am using a moving zone (mesh), I can not simply generate a line/rake as their location does not update as the blades move.
How can I do this?
Thank you very much in advance,
AvaShahrokhi is offline   Reply With Quote
Old   September 30, 2015, 06:22
Kaya Onur Dag
kaya is on a distinguished road
Can't your solver interpolate the data-you-want at a given 'position'?
If so, you know the rotation speed of the wind turbine, update your 'position' and extract the interpolated data at each time step. Your hands are tied with interpolations since you can't be sure that there is a mesh point at the point you want your data to be extracted.
If you solver doesn't provide such, extract the whole domain with mesh point coordinates at every time step and interpolate yourself.
kaya is offline   Reply With Quote
Radiation Modeling Chris89 CFX 20 August 14, 2014 08:51
Floating point exception error [High rotating speed tube] wkwong STAR-CCM+ 9 February 14, 2014 14:09
FSI: Pressure and Normal Force don't match with expected values Geraud CFX 6 August 21, 2012 16:34
transient simulation of a rotating rectangle icesniffer CFX 1 August 8, 2009 08:25
monitoring point of total temperature rogbrito FLUENT 0 June 21, 2009 18:31
