Current state of Open Source vs Commercial CFD solvers |
October 2, 2015, 13:31 |
#41 | |
Filippo Maria Denaro
Rep Power: 73 |
ok, but don't you think it should not work at all given this wrong BC.s? This is an extreme case we are talking about, and only a stupid end-user would set this case for an incompressible flow but imagine some more sophisticated problems where inflow and outflow BC.S are prescribed in such a way not to match the compatibility relation. References for the NITA in FLuent call for the Projection method and I suppose the implementation is based on that.. |
October 2, 2015, 13:43 |
#42 | |
Michael Prinkey
Rep Power: 25 |
There has been a Darwinian process involved in getting CFD in general and commercial codes in particular to their present state. The schemes are used because they (mostly) work. Iterative solvers don't offer hints at matrix singularity that direct solver do, but direct solvers don't do well on huge sparse matrices. So, we get minimum error "solutions" from iterative solvers. I think there could be pre-processing tests applied to sum up imposed fluxes on connected domains without outlets. Heck, I think if you have a mass inlet somewhere, the code should throw a warning that no outlet exists, because there must be an imbalance somewhere unless a mass sink has been applied to precisely match the influx. Last edited by mprinkey; October 2, 2015 at 15:48. |
January 10, 2016, 07:23 |
Create Profile File in Fluent
#43 |
Ray
Rep Power: 11 |
Dear All
I really and badly quick need your help. Can anybody let me know how I can create a profile file. I did much search but in vain. Someone told me I should write this (but, where should I write this and how in detail): ((pressprofile transient 2 0) (time 0 36000) (p 1.503e7 0)) Thanks. ----------------------- I write my problem down shortly: I have a porous cylindrical rock saturated with gas under pressure 2185 psi. Outside the cylinder is gas with the same pressure at time zero. As time passes, the pressure outside the cylinder is reducing with time from 1.5e7 pascal to zero in 36000 seconds. As the objective, I wanna see how the pressure inside the cylinder varies. |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 12:32 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 10:17 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 11:57 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 18:51 |
Where do we go from here? CFD in 2001 | John C. Chien | Main CFD Forum | 36 | January 24, 2001 22:10 |
