September 29, 2015, 02:19 |
All detailes of transport equation
Rep Power: 12 |
Hi
I want to add one transport equation for nanoparticle volume fraction to simulating nanofluid in microchannel . I wrote uds include udf for source term and diffusion ,but cant run by this error '"divergence detected in temperature" ------------------------------------------------- To explain better I have one transport equation (UDS(0) for volume fraction) that includes diffusion and source terms. source term is : d/dx(DT*dT/dx)+d/dy(DT*dT/dy)+d/dz(DT*dT/dz) I wanted to return sum of gradients so I calculated them in Define_Adjust. ----------------------------------------------- begin_c_loop(c,t) { C_UDSI(c,t,A1)=D_T*C_T_G(c,t)[0]; C_UDSI(c,t,A2)=D_T*C_T_G(c,t)[1]; C_UDSI(c,t,A3)=D_T*C_T_G(c,t)[2]; C_UDMI(c,t,A4)=C_UDSI_G(c,t,A1)[0]+ +C_UDSI_G(c,t,A2)[1]+C_UDSI_G(c,t,A3)[2]; } end_c_loop(c,t) } ----------------------------------------------- DEFINE_SOURCE(alpha_source,c,t,ds,eqn) { real source; source=C_UDMI(c,t,A4); return source; } ------------------------------------------ Actually I used UDS(A1-A3) for calculating gradients to return it as source term, but my property(viscosity and thermal conductivity) is dependent both of phi(volume fraction) and temperature,too. So I think momentum and energy equations cant be solved before transport equation and they all should be solved simultaneously. this makes a problem for source term, I cant solve it. ------------------------------------------ I used SIMPLEC algorithm, QUICK scheme for convection-energy, Second order for UDSI(0) ---------------------------------------- I changed UDF FACTORS but cant run again I will appreciate if you can give me more advice. |
September 29, 2015, 02:28 |
Rep Power: 12 |
According to my friend's advice I used UDMI for storing gradients and use it in source term, but still at start of one iteration gradients not calculated so
" fatal signal" returns. I used EXECUTE_AT_END and "divergence detected temperature" returns! As I said before all equation are solve together, so gradients of temperature which used in source term are unknown? maybe this sounds problem! I'm so confused and need help |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 07:27 |
turbulent diffusion term in transport equation for additional variables | Raijin Thunderkeg | CFX | 2 | May 17, 2014 23:53 |
One transport equation, two user-defined scalar, can it be solved? | sharonyue | FLUENT | 0 | April 1, 2014 23:18 |
error message | cuteapathy | CFX | 14 | March 20, 2012 07:45 |
Poisson equation combined with transport equation | Se-Hee | CFX | 0 | December 27, 2007 02:00 |
