Finite-rate H2-AIR chemistry in 1D supersonic flow
Old   November 12, 2008, 10:43
Default Finite-rate H2-AIR chemistry in 1D supersonic flow
Daniel
Hi all,
I have implemented a quasi-1D supersonic combustor-code for scramjet applications with an implizit 2nd-Order-Upwind finite differences discretization of the unsteady conservative Euler equations, coupled with the conservation equations for the spezies concentrations. The solver shows very good stability and quick convergence (< 500 timesteps) for ideal gas or equilibrium chemistry using CFL-numbers in the range of 1-2. But for finite-rate chemistry, the timesteps have to be very small (CFL < 1e-3), because of the chemical source term, which leeds to extrem numbers of timesteps (<50000) until convergence is acieved. I wonder if this behavior is normal, or something's wrong with my code (the solution looks OK). Is there any possibility to accelerate the solver, or to increase the timestep, so that the chemical source terms do not result in an unstability. Thanks for any advice.
Cheers Daniel
Old   November 13, 2008, 05:44
Default Re: Finite-rate H2-AIR chemistry in 1D supersonic
Rami
Daniel,
It is quite usual that the kinetics prescribe small time step. One way to accelerate the solution is to switch off the reaction and run to convergence, then switch it on, reduce the time step as necessary and restart.
I hope this helps, Rami
Target Mass Flow Rate Nitin FLUENT 9 June 17, 2017 11:30
Ansys Fluent UDF - for Data Center Air flow management kedarjan Fluent UDF and Scheme Programming 13 November 13, 2013 05:20
target flow rate: varying results Ryan FLUENT 3 January 9, 2008 14:54
particle, parcel and mass flow rate balance flybird FLUENT 0 May 24, 2007 11:44
Modeling reduced flow rate in 2D Tom Smith FLUENT 2 April 27, 2007 10:04
