Calculation of Developing Flow Friction Factor
Old   September 25, 2015, 11:23
Default Calculation of Developing Flow Friction Factor
Raphael
arkie87 is on a distinguished road
All,
I am trying to simulate developing flow between two parallel plates (2-D simulation), and compute the dimensionless developing (Darcy) friction factor Reynolds product over fully-developed value of 96 (f*Re/96) as a function of dimensionless length down the channel (X^ = X/(Re D)).
From the literature, it seems that the curve of f*Re/96 vs X/(Re D) should be constant and independent of Re; however, in my simulations, in multiple softwares (ANSYS Fluent, COMSOL, my own Matlab code), i find that the curves vary with Re, and increasing Re decreases f*Re/96 for the same X/(Re D).
I compute f two ways, both of which give nearly identical results:
(1) dP/dx = 1/2 f/D rho V^2; solve for f
(2) f = 4*mu*du/dy|w / (rho V^2) (factor of 4 to convert from Fanning to Darcy)
p is static pressure, but ive tried total pressure as well, and it doesnt fix the problem.
Is this correct? What am i doing wrong?
Would appreciate any help,
arkie87 is offline   Reply With Quote
ansys, comsol, developing flow, friction factor, matlab
Nusselt and friction factor validation in turbulent flow me.po FLUENT 7 July 24, 2023 04:16
need help for calculating friction factor rahulv CFX 6 February 28, 2018 08:39
pulsatile blood flow - developing larger pressure in the fluid domain KushalJ CFX 4 April 29, 2015 01:14
Volume flow rate calculation wanna88 FLUENT 0 December 3, 2014 03:35
Skin friction factor Ali FLUENT 2 December 11, 2005 04:25
