free convection
Old   November 6, 2008, 06:19
Default free convection
venkat
hi all, here is a simple textbook problem: "free convection(of air) on a vertical flat plate"...
my approach: plate is at a uniform temperature 0f 100 deg c. i have taken a rectangular domain surrounding one side of the plate. one boundary condition is clear i.e plate at uniform temperature. Apart from this, i know only air temperature when it is still. now, i want to know how can i apply other boundary conditions.
Am i clear?
Old   November 6, 2008, 11:47
Default Re: free convection
Wiebe
Hello Venkat,
You will have to decide how you want to reach that average temperature. A "classic textbook problem" would be to set the temperature of the opposite wall to a lower temperature (top and bottom adiabatic).
Good luck, Wiebe.
Old   November 7, 2008, 06:15
venkat
Hi i am sorry....could u be more clear on that plz? thanks
Old   November 7, 2008, 08:49
Amod
Which software are you going to use?
In CFX, you will have to set Inlet and "Outlet/Opening" B.C. For buoyancy-driven flow, you need to set the reference density or reference temperature. Try to set reference density as per solver recommendation (I guess it is the lowest density that can occur at a point inside the domain).
However, the most important is to set the pressure at the lower face! The hydrostatic presssure equivalent to (rho*g*h) should be set at the lower face!
|A|
Free Stream Temperature in natural convection problem tomcatbobby FLUENT 2 January 27, 2011 06:41
URGENT!!!! Combined free convection Mahyar FLUENT 0 August 13, 2008 01:39
CFX-5.5 simulating air free convection Dustin Lee CFX 0 April 16, 2003 03:54
Free Convection in STAR-CD George Hampel Siemens 0 November 16, 2000 00:38
free convection heat transfer from a heated horizontal surface through a liquid to a thin cooled fin Kaushik FLUENT 1 May 8, 2000 07:47
