September 20, 2015, 09:01 |
how to choose turbulence model?
Reza
Rep Power: 14 |
I am wondering if anyone knows references in which explains how to choose the proper turbulence model based on the model description. for example, I am interested to know when I should change from k-epsilon to LES or maybe for a problem I have LES is an overkill. I usually start with k-epsilon realizable but I do not know how I can know before hand which method is the most proper one based on the characteristics of my case. I appreciate if anyone can send me references if there is any since I couldnt find any myself. most of the links I find are describing the turbulence model details rather when to use a specific model. tanx |
September 20, 2015, 15:07 |
#2 | |
Filippo Maria Denaro
Rep Power: 73 |
the answer you are looking for depends on the flow problem and on what is the goal of the simulation... (U)RANS -> DES-> LES -> DNS from left to right is the formulation you can adopt and the more at left you stay, the lesser are the resolved details in the solution and greatest is the effect of the turbulence model. You can have a look to some textbooks, for example Wilcox as well as the book of Pope |
September 21, 2015, 01:42 |
Jingchang.Shi
Rep Power: 14 |
I got some tips at this forum, But I forget which thread it is.
September 21, 2015, 04:13 |
#4 | |
Surya
Rep Power: 12 |
http://jullio.pe.kr/fluent6.1/help/html/ug/node402.htm http://www.innovative-cfd.com/turbulence-models.html |
September 24, 2015, 15:49 |
#5 | |
Lucky
Rep Power: 66 |
It may be difficult to choose between models within a class (say k-epsilon versus k-omega) but the choice should never be difficult between a RANS model compared to LES. A better question is how much turbulence modelling do you want to do?
The choice is similar to asking whether you want to invest in penny stocks or NASDAQ/DOW. |
k-epsilon, les, turbulence |
Use of k-epsilon and k-omega Models | Jade M | Main CFD Forum | 40 | January 27, 2023 08:18 |
new turbulence model in Fluent | C.C | FLUENT | 0 | August 29, 2013 11:44 |
What model of turbulence choose to study an external aerodynamics case | raffale | OpenFOAM | 0 | August 23, 2012 06:45 |
Low Reynolds k-epsilon model | YJZ | ANSYS | 1 | August 20, 2010 14:57 |
question about turbulence model selection and sensitivity | karananand | Main CFD Forum | 1 | February 26, 2010 05:41 |
